I was looking at the bhq sponsors and cant find one who does crank work. I bought a banshee that needs new rods and bearings, plus id like it trued and welded. Anyone know what sponsors do this?
Is it worth it to rebuild? Or does it cost the same as buying a good condition one?
depends what all needs to get done you could buy a "good" used one and have it be worse off then having yours done and knowing its good
I charge $400 for full crank rebuild. This includes teardown, inspection, re-assembly, true and weld. I use hotrods connecting rods and OE quality Koyo or HIC bearings. Bearing upgrades are available.
-Brandon
Most crank failures are because the rod big end bearing goes bad. Does it trash the crank pin when this happens? If so, what are the "this crank is not rebuildable", signs that are obvious without even pressing it apart?
i had brandon do a couple of 4mills for me. great deal and great work. rebuilding a crank, or buying a new crank are about in the same ball-park, moneywise, unless yours is completely trashed, but having it built by a guy like brandon, you know it's done right. mass production cranks, you know there are always going to be a few bad units, and you might not find out for a year or so.
In that case I would recommend looking for a good web or different crank that does or doesn't need rebuilding. I shelf good parts from junk cranks here. I have several good inner webs on the shelf.
better off to buy an aftermarket. If you have to have yours done. Twister is who to call
Seriously? How long would that take do ya think?
