Looking at the dirty pictures, you play in mud and grit. The heim joints usually wear considerably quick in these conditions so you may want to thread some ball joints in place. Also, you REALLY should throw some cotter pins in your upper and lower joint studs.
The arms are adjustable, so tuning the caster, camber, and toe in for your riding style will help the performance.
Pm bansheeboie on here Thoes arms look exactly like the ones he has that he believes to be lonestar. He bought a set of elkas from me and the lower spring was a little bigger then the works and it was jammed against the a ARM no workie. So be careful not worth shit if they don't work for you. But if u planned on using them 16 3/4" elkas I seen on bike or whatever they were, I will tell you there not gonna work same problem he ran into. Hope this helps
