Jereme6655 Posted November 7, 2012 Report Posted November 7, 2012 Check that while you were looking around and such that you didn't mistakenly knock the tube that goes between the two carbs loose......this is the choke tube.......if the tube isn't connected then only one of your carbs will be choking itself to start that cold motor. Quote
Mcaff Posted November 7, 2012 Author Report Posted November 7, 2012 Checked over the hoses etc and all is ok, I got the bike started on about the 5th kick, the bike wanted to idle however it just kept dropping off and I just let it die as I had to get reddy to go out. So I'm going to let my friend have a look over it and adjust the carbs as he knows a hell of a lot more than me, I would just be guessing. I still recon something is wrong with the bike I will let my friend have a look and see what he thinks and report back. Thanks again for everyone's help! Quote
