hotrodbanshee Posted October 30, 2012 Report Posted October 30, 2012 (edited) Thinking about going to 28 pwks, read really good things about them and have some questions. I am running the stock carbs with tors 340 main jets, 27.5 pilot jets, stock needle on 3rd clip with k/n clamp on filters and 100LL avgas at sea level and runs really good. Motor mods HJR dune/play port, weisco prolite .020 over pistons, stock stroke, noss head 19cc domes, 6 degree timming advance, vforce 3's, lighten flywheel, toomey T5's making bout 63hp. What all do I need to buy? Will the 28pwk's fit my stock intake boots? Can I still use the k/n pods from my stock carbs? What do I do with the TORS? What jetting(mains, pilots, and needles would I need to use in the pwk's to match the jetting of the stockers? I want to keep using my thumb throttle. Edited October 30, 2012 by hotrodbanshee Quote
Coupelx Posted October 30, 2012 Report Posted October 30, 2012 Stock boots will work. Filters should but it might be tight. As for jetting probably start with a 140 main and 40 pilot. I ran the lgn needle i think with t5 pipes. Disconnect the tors box by the coil and throw away. Use a cable for stock carbs WITHOUT tors. Quote
Surfrjag Posted October 30, 2012 Report Posted October 30, 2012 i went from similar jetting as you on stock carbs to 45/155 on my pwk28's with a n68a needle Quote
hotrodbanshee Posted October 30, 2012 Author Report Posted October 30, 2012 Ya'll think i will notice a difference running pwk's over stock? The reason I want to change is because my stock carbs keep leaking uel around the bowel gaskets. Just put new gaskets on and sprayed them with copper sealent and they still leak. Quote
robert0762 Posted October 30, 2012 Report Posted October 30, 2012 The pwk is much more responsive to tuning in my experience. I love mine and will never run stock carbs again Quote
hotrodbanshee Posted October 30, 2012 Author Report Posted October 30, 2012 Can I expect any HP increase going to 28 pwk's? Where should I order from? What size jets should I get extra to be able to jet up or down if I need too? Quote
hotrodbanshee Posted November 1, 2012 Author Report Posted November 1, 2012 Ok if I was to go with 33 pwk's would they work good with my setup or would I loose to much bottom end over the 28 pwk's? I trail ride and drag race so I want a good all around setup. Thinking about going to 28 pwks, read really good things about them and have some questions. I am running the stock carbs with tors 340 main jets, 27.5 pilot jets, stock needle on 3rd clip with k/n clamp on filters and 100LL avgas at sea level and runs really good. Motor mods HJR dune/play port, weisco prolite .020 over pistons, stock stroke, noss head 19cc domes, 6 degree timming advance, vforce 3's, lighten flywheel, toomey T5's making bout 63hp. What all do I need to buy? Will the 28pwk's fit my stock intake boots? Can I still use the k/n pods from my stock carbs? What do I do with the TORS? What jetting(mains, pilots, and needles would I need to use in the pwk's to match the jetting of the stockers? I want to keep using my thumb throttle. Quote
possum Posted November 1, 2012 Report Posted November 1, 2012 i would do -35 pwks if it were me. Quote
SandSlingerOR Posted November 2, 2012 Report Posted November 2, 2012 28pwk's are a great upgrade over the stock carbs, very easy to tune. You'll like them. Quote
