i know this is a common problem with the pivot joint geting jammed up because the spacer rusts up.i got a new to me durablue axel in a roundhose carrier and i can get it to move like 6 '' in the rite direction .but then it jus hangs up??anyone ever have an axel do this? ive tried the BFH with lil success. :thanks: again
This has happen to me several times. The axle bearing are seized up and not letting the axle slide out. You will have to use a torch & PB Blaster to heat it up and get it, its going to take you awhile but it will eventually break loose.
