shakar Posted October 21, 2012 Report Share Posted October 21, 2012 i know this is a common problem with the pivot joint geting jammed up because the spacer rusts up.i got a new to me durablue axel in a roundhose carrier and i can get it to move like 6 '' in the rite direction .but then it jus hangs up??anyone ever have an axel do this? ive tried the BFH with lil success. again Quote Link to comment Share on other sites More sharing options...
Infamous039 Posted October 21, 2012 Report Share Posted October 21, 2012 This has happen to me several times. The axle bearing are seized up and not letting the axle slide out. You will have to use a torch & PB Blaster to heat it up and get it, its going to take you awhile but it will eventually break loose. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted October 22, 2012 Report Share Posted October 22, 2012 Put it in a hydraulic press. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted October 22, 2012 Report Share Posted October 22, 2012 BiggerFH you already got it to move 6" so it's not seized Quote Link to comment Share on other sites More sharing options...
