So i bought a banshee frame with alot of goodys and a motor and the guy said it need it top end work, which is common with banshees so i was like i might aswell change rings etc to make the motor run good, when i get home i take most of it apart and had no pistons, the cylinder walls look good maybe a hone but then i see that the crank wont spin freely one of the rods is in there tight and the other one the stuck one has alot of play in to i went ahead and got me the clutch and crank tools to actually take the complete motor apart and inspect it.
here are my questions.
1-how can i check the walls.
2-what pistons size( trying to keep it stock for right now) has fmf pipes and silincers on it.
3-i want to take it so it can get inspected for everything but dont know people here in ga that can.
4-are the husk clutches any good??
5-how big of a difference will it make if i put cool head on it?
thanks
