I figured I would see if there is any interest in these cylinders. Pretty much just bolt on and go. It’s a 400 cc stock stroke 68mill bore cheetha cylinder. I picked this up on the site awhile back and never even ran them.
The domes are cut by redline racing for pump gas at sea level.
There is one slight problem with the cylinders. somehow one of the cylinder studs pushed its way into the intake. I talked to a few people about it, they have all told me that it will seal up and pass a leak down test.
The v-force reeds are pretty much new. The pistons are in good shape
This set up come with
Cylinders
Polished cheetha head
pistons
V-force reeds
upp intakes
NEW intake gaskets
New o-ring kit for cheetha
Domes cut for pump gas @ sea level.
Base gasket
$740
I will also work a deal on a set of shearer in frame pipes, Hinson basket with straite cut gears, JJ&A dune and play axle or dune and play ported stock cylinders.
Will also throw in 10 cool points.
I put a 400 Cheetah together 2 yrs ago, it had the same problem inside the intake. It had no affect on it. It still runs today.
My buddy has a super clean set of shearer inframes I will see if he would trade you if ya want?
Im not looking to trade strate acrost. If he's down to throw in some cash we might be able to work sompthing out.
