2006Shee SE Posted September 21, 2012 Report Posted September 21, 2012 So my banshee will not idle, it starts occasionally but will not idle. It runs past 1/4 throttle and seems to be backfiring a lot. I am new to banshees and not sure where to start, I took the carb apart and cleaned it, put fresh gas in and nothing. If I can get it running it drives fine, but I cant let it go below 1/4 throttle. Ran perfect before, started first kick and ran like a top. I dont know what happened. Please help!!!! Quote
2006Shee SE Posted September 21, 2012 Author Report Posted September 21, 2012 Also, I have unplugged my TORS and my parking brake stuff. It also happened once I moved all my wiring from the back of the quad to the front, (I forget what those boxes are called) I have checked all my connections and am getting good spark. Quote
toytech Posted September 21, 2012 Report Posted September 21, 2012 pilot jets plugged, remove them and clean them. make sure the choke ube is betwween the 2 carbs. slides could be in the wrong carbs. Quote
2006Shee SE Posted September 21, 2012 Author Report Posted September 21, 2012 pilot jets plugged, remove them and clean them. make sure the choke ube is betwween the 2 carbs. slides could be in the wrong carbs. Ive had the carbs appart, pilots are and were clean, choke tube is there, I havent checked the slides but I am 99.9% sure they are on the same side they came off of. Quote
sheerider11 Posted September 21, 2012 Report Posted September 21, 2012 Ive had the carbs appart, pilots are and were clean, choke tube is there, I havent checked the slides but I am 99.9% sure they are on the same side they came off of. So that means you don't know. Quote
2006Shee SE Posted September 21, 2012 Author Report Posted September 21, 2012 So that means you don't know. No need to be an ass man. If i could ckeck now I would but I have somehting called a JOB. Quote
toytech Posted September 21, 2012 Report Posted September 21, 2012 (edited) No need to be an ass man. If i could ckeck now I would but I have somehting called a JOB. he was just being funny, don't take it so hard. if they are correct, then you might want to check your wiring over again. Edited September 21, 2012 by toytech Quote
2006Shee SE Posted September 21, 2012 Author Report Posted September 21, 2012 he was just being funny, don't take it so hard. if they are correct, then you might want to check your wiring over again. Sorry, shitty day. Im going to double check that tonight and go over my wiring, it just seems so strange that it would just happen like that as soon as I move a couple of boxes around. I think I have a different problem which just happened to show up after I did my wiring. Also at first it started and then revved wide open, so i killed it and tryed again, same thing happened. Then I tore the carbs appart, cleaned them, and now I have it start hard but run good past 1/4 throttle. Also a lot of loud backfiring. Quote
BeeCanBanshee Posted September 21, 2012 Report Posted September 21, 2012 Reved wide open on its own? If so I had a similar prob and had a broken reed Quote
sheerider11 Posted September 21, 2012 Report Posted September 21, 2012 he was just being funny, don't take it so hard. if they are correct, then you might want to check your wiring over again. Yeah man its a joke not a dick, don't take it so hard. But for real, a runaway idle is either a lean condition or a hung up throttle. Quote
2006Shee SE Posted September 26, 2012 Author Report Posted September 26, 2012 All sorted out guys, starts first kick. Quote
dunesovertrails Posted September 28, 2012 Report Posted September 28, 2012 All sorted out guys, starts first kick. What was the problem?? Quote
Jorge_pg Posted June 29, 2015 Report Posted June 29, 2015 Yeah what was it??? All sorted out guys, starts first kick. Quote
Jorge_pg Posted August 22, 2017 Report Posted August 22, 2017 Hate when people don't post the solution, only good enough to ask for help but then leave everyone hanging... 1 Quote
ginger Posted August 23, 2017 Report Posted August 23, 2017 hate when people bump 5 year old posts. 1 Quote
