sootman73 Posted September 20, 2012 Report Posted September 20, 2012 Take a look at this kit I found. I think this is the bulbs the stock headlights use? This kit isn't that pricey compared to doing a DC conversion and buying a VDC HID light kit. http://www.rigidindustries.com/MR16-HID-p/rgdmr35set.htm Quote
So Cal Suspension Posted September 20, 2012 Report Posted September 20, 2012 Take a look at this kit I found. I think this is the bulbs the stock headlights use? This kit isn't that pricey compared to doing a DC conversion and buying a VDC HID light kit. http://www.rigidindustries.com/MR16-HID-p/rgdmr35set.htm You will still need a DC Conversion and a battery to run those lights. Stock headlights use an H6M bulb, not an MR16. MR16 is what Trail Tech/lazerstar/walmart lights use. Also, a DC Conversion costs you $42.00 for the reg/rec, $15-20 for the battery and the H6M HID kit is about $30.00 shipped. Quote
sootman73 Posted September 20, 2012 Author Report Posted September 20, 2012 You will still need a DC Conversion and a battery to run those lights. Stock headlights use an H6M bulb, not an MR16. MR16 is what Trail Tech/lazerstar/walmart lights use. Also, a DC Conversion costs you $42.00 for the reg/rec, $15-20 for the battery and the H6M HID kit is about $30.00 shipped. Oh Its been a long time since i've looked at the lighting system on the banshee on another note heres what the 6in wide led mounted on a quad looks like at night Quote
