Shee keeps blowin headgaskets
06bansheeboi
Sick of my banshee blowing head gaskets, should I ditch the stock milled cylinder head for a noss cool head? Or is it a waste of time?
if the head is junk, get a coolhead, noss, chariot, prodesign. all good. all use same domes.
and check to make sure your cyl decks are flat and even.
That would probably be a good way to check, is it always leaking or blowing at the same spot?
cant tell where its leaking but it last about a month, then out of nowhere it spits coolant out to a certain poiint. Then after that it starts putting out compression bubbles in my over flow. Bike doesnt run lean. and still runs good threw this problem
Once you blow a head gasket on a stock head you are going to play hell keeping a gasket in it unless you have the head trued! Stock heads do not hold up well after they blow a gasket once. If it keeps blowing it then your head is not flat any more and that is why it is doing it.
