emtbanshee Posted September 14, 2012 Report Share Posted September 14, 2012 So one of my sand paddle beads is leaking. Any suggestions. I'm going to Phil's on Sunday and I'm hoping to get it straight before then. I appreciate any suggestions. Quote Link to comment Share on other sites More sharing options...
Rustynail Posted September 14, 2012 Report Share Posted September 14, 2012 So one of my sand paddle beads is leaking. Any suggestions. I'm going to Phil's on Sunday and I'm hoping to get it straight before then. I appreciate any suggestions. go to your local parts store and get a can of bead sealer! Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted September 14, 2012 Report Share Posted September 14, 2012 Break it down and blow the sand out of the beads, reseat the beads and you will be good to go. I would NOT use a sealer until you have tried this because bead sealer is messy. I have been able to fix all my bead leaks this way except 1 that the rubber was tore on the edge of the tire. Quote Link to comment Share on other sites More sharing options...
5150banshee Posted September 14, 2012 Report Share Posted September 14, 2012 Break it down and blow the sand out of the beads, reseat the beads and you will be good to go. I would NOT use a sealer until you have tried this because bead sealer is messy. I have been able to fix all my bead leaks this way except 1 that the rubber was tore on the edge of the tire. I have done this twice and has worked both times, just remove the paddle clean it and re set like he said u will be good to go Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
