im trying to see if i can fit the drag axle into my stock carrier for the last race of the season before i do a complete drag frame. i was told i can use the 04 yfz 450 bearings but i was curioius if the spacer on it was the same as well. this is what i was thinking. http://www.ebay.com/itm/LONESTAR-TWIN-ROW-BEARING-CARRIER-REBUILD-KIT-YAMAHA-YFZ450-03-04-/270886356328?pt=Motors_ATV_Parts_Accessories&hash=item3f1215c568&vxp=mtr
thanks for any help..
You are going to need the right size bearings ID/OD/W. You will need a piece of pipe for a center spacer and the bearings you can get at NAPA.
Banshee: 35/62/14
YFZ: 40/62/12
That link you posted is double row bearings. Not even close to working. Stock bearings are single row. What you want to do is possible, but to do it right, it's too much work for 1 race. You would need to take very precise measurements and make a spacer tube and outer bearing race spacer rings in a lathe. The problem is that 62 X 40 bearings are narrower than 62 X 35 bearings, so you need a wider space between the bearings for the sprocket and brake disc to line up properly. You can probably half ass it with a piece of water pipe and a hack saw, but things could come apart or fail and destroy other parts or cause a crash.
