Call up Jeff at FAST and get his carb sync tool, $50. Can be.used on any twin+ motor. adjust screws until both are showing the same pull on the tool and when it sounds right. there's a video on YouTube to show how the tool works, might also be in the technical section here as well if I can.remember right. Do your adjustments in 1/4 turns, one carb then the next and so on. Be sure to start from turned in all the way.
