Uf21 Posted August 30, 2012 Report Posted August 30, 2012 (edited) I have pre ordered the v force 4 reeds. Is there anything else I need? I see that the reeds sit in a cage. Do they fit in the stock reed cage and do I need anything else? Sent from my GT-I9300 using Tapatalk2 Edited August 30, 2012 by Uf21 Quote
NYUK Posted August 30, 2012 Report Posted August 30, 2012 they replace the stock reed cages, you will probably need to trim the inside of the intake boots. shave off the 4 tits with a razor. Quote
Uf21 Posted August 30, 2012 Author Report Posted August 30, 2012 they replace the stock reed cages, you will probably need to trim the inside of the intake boots. shave off the 4 tits with a razor. Wait, so does the v force 4 come with its own cage or I don't need a cage at all with the v force 4? Sent from my GT-I9300 using Tapatalk 2 Quote
Fakkundo Posted August 30, 2012 Report Posted August 30, 2012 Wait, so does the v force 4 come with its own cage or I don't need a cage at all with the v force 4? Yeah, VF's assembly include cases + petals, no additional parts needed. You'll probably need to cut the intake boots as John mentioned, you'll receive a detailed whitepaper with the installation steps. Quote
Uf21 Posted August 30, 2012 Author Report Posted August 30, 2012 Yeah, VF's assembly include cases + petals, no additional parts needed. You'll probably need to cut the intake boots as John mentioned, you'll receive a detailed whitepaper with the installation steps. Ok thank you. Sent from my GT-I9300 using Tapatalk 2 Quote
