87BRBanshee Posted August 30, 2012 Report Posted August 30, 2012 I bought a 87 banshee that already had a twist throttle on it but one of the prev owners had rigged it up after it broke so I bought a potion pro twist throttle kit, and I am buying a set of T-5's this weekend and i plan on getting the perfect jetting kit with the air fiter and box vents. Will i have to do anything else with the carbs or jets? I noticed something about an idle kit? Do all twist throttles need an idle kit for the carb? And will i be fine when i go to put the new jets for the pipes in? Quote
guns4children Posted August 30, 2012 Report Posted August 30, 2012 It depends on what cable your running with the twist throttle. The banshee comes with big ulgy tors on the top of the carbs. Its definitely worth the money to get the tors delete with you still have it. Quote
87BRBanshee Posted August 30, 2012 Author Report Posted August 30, 2012 It depends on what cable your running with the twist throttle. The banshee comes with big ulgy tors on the top of the carbs. Its definitely worth the money to get the tors delete with you still have it. I dont think it has the tors on it. the carbs are 36mm Mikuni's and the cable runs right to the caps. The twist throttle kit didnt seem like anything special, just a cable with the one end for the throttle and the other split end for the tops of the carbs. Quote
guns4children Posted August 30, 2012 Report Posted August 30, 2012 Then I would think you should be fine. Quote
