velle67 Posted August 7, 2012 Report Posted August 7, 2012 I am new to this forum so I would appreciate any help anyone has to offer. I am currently rebuilding my first Banshee, it is a 1996. The previous owner broke a piston skirt off and scored the cylinder wall pretty bad but is still within resleeving range. He had already bought the pistons and rings and they are as follows: Wiseco 513M06475 Pistons 65.75 mm and Wiseco 2549CD Rings 64.75mm. My first question is the fact that they are different sizes. Are they compatible and are they just measured differently since the rings are obviously smaller than the pistons? I am usually working on my Chevelles and rings and pistons are generally listed as the same diameter but are these normally listed differently? Also, what size sleeves should I be looking for? The heads are stock and will need to be bored to accomodate the new pistons. I am simply looking for the sleeve size that I need and are the rings and pistons that he gave me going to work together? I appreciate any and all replies and if anyone needs more info, just let me know. Thanks Quote
sheerider11 Posted August 7, 2012 Report Posted August 7, 2012 Those aren't sleeve sizes. You can just bore it if the gouge isn't bad. You don't need to touch the head. I'm not sure about the off numbers tho. I always got them as a kit and never really checked the numbers on the rings. Quote
hoppedupandcutdown Posted August 7, 2012 Report Posted August 7, 2012 Double check your numbers. The 513mo6475 IS 64.75, that's the part number and size. So those are the correct rings. wiseco does not offer a 65.75. I believe you are calling the cylinders - heads. The cylinders can be bored out many over sizes safely. Those pistons are 3 sizes overbore and will take out a pretty fair sized scratch. I highly recommend you send your pistons and cylinders to a sight sponser to have bored,they call tell you if your gouge is repairable, or you need to find a used cylinder or install a sleeve - Quote
velle67 Posted August 7, 2012 Author Report Posted August 7, 2012 The piston box actually says 65.75 on it so I was just curious if they were measured differently. The previous owner had a local shop look at the heads and was told that it would definitely need to be resleeved. The gouge was a bit too deep even for the oversized piston. So the sleeves I should get are all one size and I won't need to look for any particular size for these pistons? Quote
hoppedupandcutdown Posted August 7, 2012 Report Posted August 7, 2012 BANSHEE CYLINDERS BANSHEE HEAD REPAIR SLEEVE BY LA SLEEVE First we need to get our terms correct... Quote
hoppedupandcutdown Posted August 7, 2012 Report Posted August 7, 2012 --Heavy Duty replacement sleeve by LA Sleeve . Will accept bores up to 69.5mm. LA Sleeve part#YA-5023H,-- If you really want to sleeve it, your machine shop will have to bore for the sleeve and then bore the sleeve for your pistons. i would think a good used cylinder would be the cheaper way to go. here's a link to wiseco, I don't know what you got = http://www.wiseco.com/ProductSearch.aspx Quote
velle67 Posted August 7, 2012 Author Report Posted August 7, 2012 I am having a friend do the machine work so the price won't be an issue. Even if I bought used cylinders than I would have that cost in addition to the machine work since I already have a brand new set of pistons and rings. Are LA Sleeve the best ones to buy or did you just use them as an example? Right now I only have $400 in it and still have some extras to sell that he threw in when I bought it. I still have a brush guard for a 3/4 ton Chevy/GMC to sell if you're interested, lol. I figure when I've sold everything else I will have basically gotten the Banshee for $200 plus whatever I have in the machine work and sleeves. I just want someone's expert opinion on which sleeves to buy and you already answered my question about the pistons and rings. Quote
hoppedupandcutdown Posted August 7, 2012 Report Posted August 7, 2012 I am having a friend do the machine work so the price won't be an issue. Even if I bought used cylinders than I would have that cost in addition to the machine work since I already have a brand new set of pistons and rings. Are LA Sleeve the best ones to buy or did you just use them as an example? Right now I only have $400 in it and still have some extras to sell that he threw in when I bought it. I still have a brush guard for a 3/4 ton Chevy/GMC to sell if you're interested, lol. I figure when I've sold everything else I will have basically gotten the Banshee for $200 plus whatever I have in the machine work and sleeves. I just want someone's expert opinion on which sleeves to buy and you already answered my question about the pistons and rings. LA Sleeve is the only one i've ever heard of. I figured someone on here might have one used cylinder way cheaper than a sleeve. What did you figure out on your piston and rings? Quote
velle67 Posted August 7, 2012 Author Report Posted August 7, 2012 I will check into a used cylinder. That hadn't crossed my mind but the cheaper I can build this the better. I only need one since it is gouged fairly deep. I am assuming there is enough meat to bore the stock cylinders to 65.75 without any issues? I am at work right now but I am positive the piston box had 65.75 on it and the rings had 64.75 on them. I will ask the guy I bought it from and see if he bought them as a kit or if he bought them separate. I'm pretty sure he bought everything from Cycle Specialties in Fairfield, Ohio. Quote
bansheesandrider Posted August 7, 2012 Report Posted August 7, 2012 Whether you resleeve your cylinders OR buy different cylinders, I would not recomend boring them to 64.75mm because that is what you have for pistons. If you resleeve you can start with a fresh 64mm bore and get maximum life from your cylinders/sleeves. If you buy used cylinders, only bore them as needed to get a smooth, round, straight bore.As far as stock cylinders go, boring is a machine operation to repair worn or damaged cylinders, there will be no gain in power from going to a bigger bore than what is needed to cleanup the wear or damage. I would either sleeve your cylinders(especially if they are ported) or find some repacement cylinders, get a smooth, straight round bore on them, buy pistons to fit and SELL the pistons and rings you already have. By the way, if the pistons you have are part number 513MO6475 then they ARE 64.75mm pistons and the rings should be the same size as the pistons- It does not matter if we are talking ATVs, motorcycles,cars, diesel trucks or whatever, if it says it is for a certain size bore that is what bore it fits, NOT what they actually measure. Quote
velle67 Posted August 7, 2012 Author Report Posted August 7, 2012 So the factory pistons were 64 mm? I understand all the machining and boring, I've built enough engines. I just wasn't sure if for some reason the dimensions for these were somehow listed differently. As my piston box clearly says 65.75 mm and the rings have 64.75 mm on them. Maybe it is a misprint on their part, who knows? So, from the advice I've gotten so far I will weigh out all the options and see what is the most feasible and economical. I know he spent a lot of money on the pistons and two sets of rings but if I can go back to 64's or the factory size and not be into it for a lot more money than I will. I don't really like cutting into the cylinders unless it is an only option but since I already have new pistons and rings I will see what the cost difference is. Quote
velle67 Posted August 7, 2012 Author Report Posted August 7, 2012 What specs should I give the machine shop to bore the cylinders? If I use the 64.75 mm pistons what would the bore be and what would the bore be for the sleeves? Quote
sheerider11 Posted August 7, 2012 Report Posted August 7, 2012 What specs should I give the machine shop to bore the cylinders? If I use the 64.75 mm pistons what would the bore be and what would the bore be for the sleeves? The sleeves have to be pressed in and bored. And if you get a sleeve pressed in that's 64.00. You don't need to bore it. Quote
velle67 Posted August 9, 2012 Author Report Posted August 9, 2012 Now that I have my bearings together on everything and took a good look at the old cylinders I have come up with some options. First, I am going to have the machinist look at the cylinder and see if he thinks it can be bored to fit a 64.75 mm piston. Only one of the cylinders was hurt so I know the other can be bored with no issues. These are factory cylinders so I believe the cylinders were cast around the sleeves which would have to be bored out to resleeve. If it needs to be resleeved I will be deciding whether or not to find a used cylinder and purchasing new 64 mm pistons and going back to a stock set up or what the price difference will be to resleeve it and stick with the 64.75 mm pistons that he sent with it. Like I said earlier, my experience has been with old muscle cars and this is something new to me. I am not worried about super performance and what I've gathered from everyone is there won't be any noticeable change from the factory 64 mm to the 64.75 mm pistons. I need to have a fairly cheap build but not risking any quality in the process. I will be running the cylinders over early next week for him to look at so I will know more then. What would anyone else suggest? Does anyone know of someone with stock cylinders in the Cincinnati, Ohio area that would be able to be bored to a 64.75 mm piston? Thanks for all of your ideas and suggestions. Quote
