bansheeboi Posted August 1, 2012 Report Posted August 1, 2012 the crank gear nut back off the crank and made a groove in the case... the last pic is the oil pan that bloch is the shaving i clean out the case help guys what i need to do? the last pic is t Quote
BigRed350x Posted August 1, 2012 Report Posted August 1, 2012 Not torq'd to spec. If you torq the nut to spec it will stay right where its supposed to. It also looks like you are missing the locking washer that sits behind the nut. -Jared Quote
bansheeboi Posted August 2, 2012 Author Report Posted August 2, 2012 Not torq'd to spec. If you torq the nut to spec it will stay right where its supposed to. It also looks like you are missing the locking washer that sits behind the nut. -Jared Ok thanks bro by the way do u have a fresh nut an the locking washer handy if so how much also u got a fresh gasket for the cover? Quote
BigRed350x Posted August 2, 2012 Report Posted August 2, 2012 Ok thanks bro by the way do u have a fresh nut an the locking washer handy if so how much also u got a fresh gasket for the cover? cascade sells the washer and nut for just a few bucks and you can pick up the gasket from them as well. www.cascadeinnovations.net Quote
