No drill bit needed, just cut the bridge off when you take the stock pingle off. The dual pingle should slide right into the hole, make sure you use yamabond or some type of gas resistant sealer to make sure you dont get any leaks.
Can anyone tell me what drill bit size you would use to drill out the bottom of the gas tank to add a dual pingle?
was you intending to drill a hole for a 2nd stock gasvalve? why the drill??:confused: ,,,,,,,,,,goodluck
