What's your chassis setup? Tires being used? Swinger length? Stock chassis?
I'm having the same problem and after some discussion I'm needing more paddles for my weight, swinger length, etc. I'm also working on clutch tuning also. Give soon more info and someone with some experience will chime in.
Need more info on what your tryin to do exactly. How are the races setup by you? Time classes or cc classes? How much are you looking to spend and what do you already have? Go to the races and watch and see what otger people are doing. Then come back with more soecific questions.
My chassis is stock and my swing arm is a +4 and tires is a razors . My motor is a 4 mill dune port
Edited by jdog
What's your gearing? Have you thought about Prowedges or paddles depending on the track?
Give us a full run down of your bike.
The gearing is whatever it comes stock
Here I'll tell you what I'm running on my 4mil stock cylinder bike. Stock lightened chassis, +10 swinger, struts all the way around, chariot reed cages, 35mm PWK, FAST dune port,override trans, GRR OOF, +7 timing I think, 16/41 gearing with Prowedge II's 22x11-8. I'm blowing the tires off coming out of the hole.
I'd try some Prowedges with that short arm, but that's just me. You might play with your gearing too. I take off in 2nd.
I'm no expert, I'm just getting back in the game again after 10 years.
Start with some Pro wedge two's, gearing will help you alot also but we need your weight first. I run a 16/39 and with a +6 swinger, aggresive dune port, and I am 140 pounds.
