jdog Posted July 23, 2012 Report Posted July 23, 2012 Can you get water in your oil from blowing a o ring in your cool head Quote
Jereme6655 Posted July 23, 2012 Report Posted July 23, 2012 As in your trans fluid? Not easily. I guess you could blow an o-ring and then blow a crank seal and get it in that way. More realistic is that your water pump seal cut loose and it leaked into your clutch. The easy way to check for all of this is to do a leakdown test on your motor......it is a phenomenally great tool to help diagnose problems and also ways to eliminate issues. Quote
