yanickfc Posted July 18, 2012 Report Posted July 18, 2012 Hey guy As I had to clean my carb, I said why not tors removal and idle kit! It looks good, we drilled the correct hole(left side on left carb right side on right carb, the one that we're in angle) but I'd like to know if someone has a view of idle screw from inside of the ''throat'' ? I can't figure how will those screw adjust my idle!!! Thanks Yan Quote
SAVAGE420 Posted July 18, 2012 Report Posted July 18, 2012 we drilled the correct hole(left side on left carb right side on right carb, Your kidding right? http://bansheehq.com/forums/index.php?showtopic=135591 Quote
BUILDER Posted July 18, 2012 Report Posted July 18, 2012 You have got to grind that off where the screws go in. You will end up grinding a goor 1/4" or so off of them so the screws will be long enough to reach in and hold the slides up Quote
yanickfc Posted July 18, 2012 Author Report Posted July 18, 2012 You have got to grind that off where the screws go in. You will end up grinding a goor 1/4" or so off of them so the screws will be long enough to reach in and hold the slides up yeah we did that, omg don't stress me again like that I tought I drilled the wrong hole!! But how high should the slide stay open, that is the question sorry I have a hard time to explain, I use to speak french.. Quote
yanickfc Posted July 19, 2012 Author Report Posted July 19, 2012 yeah we did that, omg don't stress me again like that I tought I drilled the wrong hole!! But how high should the slide stay open, that is the question sorry I have a hard time to explain, I use to speak french.. lol i figured what was wrong, dumb me haha Quote
