yanickfc
yanickfc's Achievements
  1. Oh, I was in the wrong diagram =/ Thank you, and by the way I have a manual at home!!
  2. Hello, I lost one of the chain adjuster bolt on my 05 banshee, anyone have the part number? I'm having a hard time to find it! Thanks
  3. you are right, he looks like it want to start when push start, there is a little smoke going thru exhaust I could try the trick with the oil in the cylinder, thanks for the help guys!!
  4. Yeah I know that compression is low and will need to do some job on top end but the question is Should the bike start with 80 and 100 psi or I am hunting for another problem?
  5. Hey guy, My 2005 banshee does't start anymore!!!! :-( We cleaned the carb pretty well and buy 2 carb rebuild kit, they guy who installed carb is a mechanic so I'll asume it's installed well. He tested and gas goes in the carb I removed a spark plug and check if I have fire, yes I have a spark when kick starting when I've tried to pull start, it would burn some gas but it's not starting When I kick start, plug don't seem to get any gas I did a compression test, 80 and 100 psi My friend told me that reed valve seemed to be ok.. what do you think, could that low compression be the probleme or should it start anyway? Oh and no more tors, brain unplug
  6. lol i figured what was wrong, dumb me haha
  7. yeah we did that, omg don't stress me again like that I tought I drilled the wrong hole!! But how high should the slide stay open, that is the question sorry I have a hard time to explain, I use to speak french..
  8. Hey guy As I had to clean my carb, I said why not tors removal and idle kit! It looks good, we drilled the correct hole(left side on left carb right side on right carb, the one that we're in angle) but I'd like to know if someone has a view of idle screw from inside of the ''throat'' ? I can't figure how will those screw adjust my idle!!! Thanks Yan
  9. in Canada, just next to ottawa
  10. Thanks!
  11. Hey Just bought a 2005 banshee without any modification, no scrateches on plastic and still have light deflector on it! I went for my first ride yesterday, I am not missing my old suzuki haha Anyway only thing I have to do with this bike is change front bearing, axle bearing, rear brake pad and figure why the hell the axle nut alway get loose!
