bball23 Posted July 6, 2012 Report Posted July 6, 2012 Is powder coating my cylinders a good idea or will the paint wear off from the heat? Also does anyone on here powder coat and could give me a price? I want the color to be dark red. Thanks! Quote
shanYE west Posted July 6, 2012 Report Posted July 6, 2012 Is powder coating my cylinders a good idea or will the paint wear off from the heat? Also does anyone on here powder coat and could give me a price? I want the color to be dark red. Thanks! Quality powdercoat is a sponsor here. Send him a PM. Quote
trickedcarbine Posted July 6, 2012 Report Posted July 6, 2012 X2 on quality powder coat. They're about 10 mins from me here so I see a lot of the work from there. Nothing but top notch from chopper frames to my buddies jeep parts. The banshee comes stock with black powder coat, so there is no worries when it comes to coating your cylinders. Quote
fappy'97 Posted July 7, 2012 Report Posted July 7, 2012 No, it should not wear off from heat. If you get say, candy red, there will be a chrome layer, translucent red layer, and possibly a clear coat, which will make it quite a bit hotter than a single stage powder, such as black. Good luck! Quote
emtbanshee Posted July 11, 2012 Report Posted July 11, 2012 X3 on QPcoating. Brian does amazing work. Quote
camatv Posted July 12, 2012 Report Posted July 12, 2012 i have experimented with candy ( translucent) red in a single stage. with some ingenuity you can do some sweet things with alluminum. if you just want boring RED you can do a stronger industrial red Quote
Mootsman Posted July 13, 2012 Report Posted July 13, 2012 How well it holds up to heat will depend on how the surface is prepped and what type of powder you use. I use hi temp powders for exhaust components and haven't had any fade or peeling. I have used standard TGIC polyesters on brake calipers and banshee jugs and they look as good as the day I coated them. Cast aluminum parts should always be preheated to allow oil, air and other contaminants to escape from the metal in preparation for coating. Quote
SandmanPNW Posted July 13, 2012 Report Posted July 13, 2012 My Cub cyls are PC'd gloss black and look and held up great Quote
Rustynail Posted July 19, 2012 Report Posted July 19, 2012 I powdercoated my clys gloss black and they look great....pay shipping both ways and i will prep and coat them for 60 bucks Quote
