33 pwks, pods no air box, F.A.S.T dune/play port, v3 reeds, toomey t5's (soon to be cpi's). ok i got the engine broke in finally after a complete rebuild and this thing is hard to start. runs great, no bogs anywhere and will flat out scream but will not start unless i choke it. carbs are setup with 165's, 52's, and cel in the middle. any advice on where to start first? thanks.
That pilot seems too big to me. I think you should be around 45-48. Main 160-162. I like the DGK needle better than the CEL.
You sure you don't have an air leak? What's your temp and elevation?
Temps are in high 90's. Elevation is sea level, im 40 miles from gulf of mexico. The motor had a complete r/r at fast by jeff. I dont think it has an air leak. It runs great once I get it started. You just have to choke it for the first crank. If I dont it takes several kicks to get it to fire.
Dropped in some155 mains tonite and shee fired the first kick an ran great. Started everytime after that on first kick. Gunna do some plug chops this weekend and see how that looks. Thanks guys
