villthepill Posted June 26, 2012 Report Posted June 26, 2012 ok was playing around with my banshee today syncing the carbs and what not. When i was reving it up and letting off fuel was spraying outta the carb vent hoses (top vent lines not the overflow) on one carb. It was leaking as it was coming down from a rev. Not sure if it is float related or needle seat related, carbs are mikuni tmx 35s flat slide's. Any help would be great. Quote
FOXBANSHEE30 Posted June 27, 2012 Report Posted June 27, 2012 ok was playing around with my banshee today syncing the carbs and what not. When i was reving it up and letting off fuel was spraying outta the carb vent hoses (top vent lines not the overflow) on one carb. It was leaking as it was coming down from a rev. Not sure if it is float related or needle seat related, carbs are mikuni tmx 35s flat slide's. Any help would be great. Did you open them? Seems like the floats are acting up... Quote
villthepill Posted June 27, 2012 Author Report Posted June 27, 2012 i opened em up they were about 4 mm off, once i get my throttle cable ill see if its better. hoping that was the problem. Quote
