Hey guys. Well I pulled the Shee out of the basement a few days ago, started right up was running great at the bottom end but right when it hit the power band it would make this sputter sound (Sounds like hitting a rev limiter in a car). Well I figure because the gas was sitting for awhile it was just shit gas. I drained all the gas filled it up with new gas and I switch to Bel-Ray MC-1 (Because my local store stopped carrying the Yamaha stuff.) I took it out for a few laps and it still wouldn't go into the power band. So I fired it up last night to mess with it for a bit it was idling and it just stalled out :( I couldnt get it to crank so I pushed it to the top of a hill and pop started it' when it fired up it had like 0 power at full throttle it would barely move. So I took the carbs apart they were clean (Cleaned them anyway). Still wont start :(
And Plugs look fine, it will roll in gear with the clutch and natural. I know that the stator was a little rusty last year when I pulled it apart.
sounds like its time for a new topend
Well just did a compression check and 130 and 131 could it still be the top end?
Also its sparking pretty good even with the rusty ass flywheel :( only thing I can think of is it hates the new 2stroke oil:(
P.S. I would edit the posts but it seems like the edit button vanishes after a few minutes?
Edited by MDalton
Yay got it started, destroyed a plug wire somehow !! But it seems that I ripped the seal for the carb bowl in my rage :( :( :( :(.
