jsinar Posted June 25, 2012 Report Posted June 25, 2012 I read somewhere, I can't remember if it was on here or not, but someone had the same issue as this, I finally got my tie rod end and wheels, was out doing an alignment, and I noticed that the rear right has a little wider offset than the left. Like if you stand directly in front of the front left tire and look back, the front and rear tires are even, if you do it on the left, the rear wheel sticks out a little farther than the front. It rides fine, pullls straight, is there anything I could do easy to fix it? Maybe pull the axle out and flip it around, would that make it more even? Quote
2004LEBanshee Posted June 25, 2012 Report Posted June 25, 2012 I read somewhere, I can't remember if it was on here or not, but someone had the same issue as this, I finally got my tie rod end and wheels, was out doing an alignment, and I noticed that the rear right has a little wider offset than the left. Like if you stand directly in front of the front left tire and look back, the front and rear tires are even, if you do it on the left, the rear wheel sticks out a little farther than the front. It rides fine, pullls straight, is there anything I could do easy to fix it? Maybe pull the axle out and flip it around, would that make it more even? Is it an aftermarket axle? If so it maybe for a raptor instead of a banshee. They will fit but be off set a bit. Quote
jsinar Posted June 25, 2012 Author Report Posted June 25, 2012 I don't think it is, I could be wrong though. Quote
shakar Posted June 25, 2012 Report Posted June 25, 2012 i have this same issue...rides fine ,jus looks odd .i believe alot of shee's rolled out of the factory like this.. why i dunno??? does anyone have any ideas?? Quote
jsinar Posted June 25, 2012 Author Report Posted June 25, 2012 I'm not really worried about it, it'll give me an advantage taking left turns. Lol Quote
WINDYCITYJOHN400 Posted June 25, 2012 Report Posted June 25, 2012 The banshee frame has an asymmetrical offset. Front and rear tires line up on the clutch side. But the stator side front is in farther than it looks like it should be. Quote
F11 Posted June 26, 2012 Report Posted June 26, 2012 I noticed this recently ... http://bansheehq.com/forums/index.php?showtopic=155668&st=0&p=1352154&fromsearch=1entry1352154 Quote
jsinar Posted July 13, 2012 Author Report Posted July 13, 2012 Ok, so while doing my axle bearings, I got out the tape measure. For some weird reason, The axle is exactly 3/4" longer on the right side than the left, measuring from the edge of the carrier, to the tip of the axle.. Anybody have an idea why they did this? Quote
