forrest411 Posted May 31, 2012 Report Posted May 31, 2012 I need to have a rod replaced on on of my cranks. Looking for a local shop in Illinois or Northwest Indiana that can replace it and true & weld it? I already have the new rods. Thanks Quote
spurdy Posted June 1, 2012 Report Posted June 1, 2012 I need to have a rod replaced on on of my cranks. Looking for a local shop in Illinois or Northwest Indiana that can replace it and true & weld it? I already have the new rods. Thanks It will likely cost you as much as a new crank will cost for the repair, unless your talking about a crank 7mm or larger. SP Quote
forrest411 Posted June 1, 2012 Author Report Posted June 1, 2012 It costs thatuch to disassamble and put it back together? I wouldn't have thought that. All the bearings arr good, the only issue was one rod bearing has too much play. Quote
rashin Posted July 1, 2012 Report Posted July 1, 2012 PM me. I know a guy in Bristol WI that I send my stuff to. He can rebuild banshee crankshafts for cheap. I am in Crown Point, IN. Quote
