erickson483 Posted May 23, 2012 Report Posted May 23, 2012 I finished my rebuild and my shee idles fine but bigs out when you give it gas, it won't rev. I'm thinking it's the parking brake but I don't even have one anymore unless there's a plug or wires I need to cut or tie together. I have the black and black/yellow wires for the throttle switch disconnected. Any suggestions? Quote
sheerider11 Posted May 23, 2012 Report Posted May 23, 2012 Disconnected from the carbs or the brain box? Quote
erickson483 Posted May 23, 2012 Author Report Posted May 23, 2012 I installed the motion pro TORS eliminator kit Quote
sheerider11 Posted May 23, 2012 Report Posted May 23, 2012 Did you unplug the box from under the tank? Quote
erickson483 Posted May 23, 2012 Author Report Posted May 23, 2012 Apparently not, the only things unplugged are headlights and throttle. What do they look like? Quote
sheerider11 Posted May 23, 2012 Report Posted May 23, 2012 Apparently not, the only things unplugged are headlights and throttle. What do they look like? If you sit on the bike it will be on the left side under the gas tank a little towards the front. Quote
03DMshee Posted May 23, 2012 Report Posted May 23, 2012 i also suggest cutting ALL wires not needed out of harness...i chased a rev limit problem till i got my shit strait and cut them all the way back to the juntions...i had an issue when i hit water it would conduct the wires and give me rev limit... Quote
erickson483 Posted May 23, 2012 Author Report Posted May 23, 2012 Got it, cut it, revs like a champ. Now I just need to solve the coolant mystery. Quote
