here are my mods starting up my fresh build tonight would like any help that anyone can offer, my mods are: 98 yamaha banshee 64.25 wiesco, vitos hemi head 2, 22cc domes, 700-1000 feat above sea level 70-85 degrees, vitos forged crank and rod assmbly, chariot 2 into 1 intake with a 35mm pwk air stryker,and pro cictuit pipes and mufflers, no port work, and if it makes a difference i will be strictly trail riding thanks in advance
also as i have not done a whole lot of jetting how do the numbers work as far as richer and leaner is a bigger jet lets say a 160 to 170 would the 170 alow more fuel aka richer or would the 160 run more fuel
Don't forget to turn the fuel back on when you fill the tank too-the motor will lean out if you forget.
