350 screamer Posted May 17, 2012 Report Posted May 17, 2012 I needed to do crqnk seals this os wat i find... One side has a seal and one side has a metal shim.... The seal is gone... That needed or wat can i just put another shim in its on the ignition side ??? Quote
erickson483 Posted May 17, 2012 Report Posted May 17, 2012 I just put my bottom end together and all that is there is a bearing and an oil seal. I mean there's a half circle metal clip that holds everything in place, but that's it. Quote
350 screamer Posted May 17, 2012 Author Report Posted May 17, 2012 (edited) I just put my bottom end together and all that is there is a bearing and an oil seal. I mean there's a half circle metal clip that holds everything in place, but that's it. on the other side is the metal clip. this side has a seal on the bearing https://www.facebook.com/groups/6362831709/ Edited May 17, 2012 by 350 screamer Quote
erickson483 Posted May 17, 2012 Report Posted May 17, 2012 You answered your own question. Throw in new seals and ditch the "shim". Quote
