skinak Posted May 15, 2012 Report Posted May 15, 2012 So to start off my specs are Mild porting .040 shaved head Force 2 reeds +4 timing And unfortunately T-6 pipes Now my issue. I got a set of stock carbs that were bored out to 28mm, and now I am seeing little air gaps on each side of the slides. My bike will start on first kick but only with half or full choke. If I close the choke it starts to high rev. The carbs have 330 mains, 27.5 idles, 4th position needle clip. Am I able to put in bigger idle jet to correct the air gaps with the slides or is there another option that I can do.. Any help would be great Thanks nick Quote
Larry's Shee Posted May 15, 2012 Report Posted May 15, 2012 The infamous stealership mechanic Ben Dover is now boreing carbs So BenD over and take it like a man, you got fucked and now need new carbs Can't have air leaking past slides. Quote
lms1977 Posted May 15, 2012 Report Posted May 15, 2012 Your only option is to jet it up.. Or get new carbs Quote
sheerider11 Posted May 15, 2012 Report Posted May 15, 2012 Your only option is to jet it up.. Or get new carbs I personally wouldn't jet to compensate. It's a temporary fix to a permanent problem. I have a set of stock carbs with the tors for sale. They came with a bike I bought. If not there is a set in the four sake section for like 50 bucks. Quote
zach45 Posted May 15, 2012 Report Posted May 15, 2012 Where is the four sake section Sent from my iPhone using Tapatalk Quote
Strm Trpr Posted May 15, 2012 Report Posted May 15, 2012 I got a set of stock carbs that were bored out to 28mm. Who bored your carbs? Quote
Starwriter Posted May 15, 2012 Report Posted May 15, 2012 I knew this was going to be the issue before I even clicked on this thread. Jeez!!! Why do people do this??? Whoever destroyed your carbs should not be allowed to use a lathe. I hope they aren't doing anything that requires any amount of precision. Quote
Starwriter Posted May 15, 2012 Report Posted May 15, 2012 Where is the four sake section Haven't you heard of four sake? Crappy garage band that plays out behind their apartment. Quote
Nightmare Posted May 15, 2012 Report Posted May 15, 2012 Haven't you heard of four sake? Crappy garage band that plays out behind their apartment. Quote
ClayAiken Posted May 15, 2012 Report Posted May 15, 2012 I would get some new carbs. You can get stockers cheap on here. Quote
sheerider11 Posted May 16, 2012 Report Posted May 16, 2012 Haven't you heard of four sake? Crappy garage band that plays out behind their apartment. Holy shit no. But why do you know that? Any way, you know I ment for sale. Quote
Starwriter Posted May 16, 2012 Report Posted May 16, 2012 Holy shit no. But why do you know that? Any way, you know I ment for sale. Just couldn't resist doing a google search to flick shit. Never heard of them before this. They sure do suck. Quote
sheerider11 Posted May 16, 2012 Report Posted May 16, 2012 Just couldn't resist doing a google search to flick shit. Never heard of them before this. They sure do suck. Haha damn I was about to say, and yeah they suck. Quote
