01yamban Posted May 15, 2012 Report Posted May 15, 2012 Can someone give me step by step instructions On doing a compression test on my 01banshee? And how much psi it should have? Thanks in advance Quote
Finch Posted May 15, 2012 Report Posted May 15, 2012 Get a compression tester. screw it into spark plug hole. turn switch to off. hold throttle wide open kick till gauge stops moving, and reapeat on othere side. Make sure bike is warmed up if possible, and that the adapter that screws into the head the threads are the same length as a spark plug. otherwise your get inaccurate readings. Quote
01yamban Posted May 15, 2012 Author Report Posted May 15, 2012 Do I remove both spark plugs even though I do one cylinder at a time? I just watch a video on YouTube and the guy said to have the gas on and the choke on is this correct? Quote
shakar Posted May 15, 2012 Report Posted May 15, 2012 (edited) Do I remove both spark plugs even though I do one cylinder at a time? I just watch a video on YouTube and the guy said to have the gas on and the choke on is this correct? http://bansheehq.com...howtopic=110585 <<< complete write up with how to diy comp tester............look around and read up ,everything you need /desire to know is on here somwhere . goodluck Edited May 15, 2012 by shakar Quote
