Get a compression tester. screw it into spark plug hole. turn switch to off. hold throttle wide open kick till gauge stops moving, and reapeat on othere side. Make sure bike is warmed up if possible, and that the adapter that screws into the head the threads are the same length as a spark plug. otherwise your get inaccurate readings.
Do I remove both spark plugs even though I do one cylinder at a time? I just watch a video on YouTube and the guy said to have the gas on and the choke on is this correct?
http://bansheehq.com...howtopic=110585 <<< complete write up with how to diy comp tester............look around and read up ,everything you need /desire to know is on here somwhere . goodluck
Edited by shakar
