01yamban Posted May 14, 2012 Report Share Posted May 14, 2012 i just put the stock carbs back on mu 01 banshee, how many turns out on the air screw to get it started? i couldent get it to start other than the rolling start then it was back firing on the ride, i just put 290mains and 27.5 pilots in it cause the 265 and 25 were a lil lean for the after market i have, i tried to post pics of the reeds cause they look dark to me and im not sure if that normal ? also i cleaned the carbs well when i jetted them. Quote Link to comment Share on other sites More sharing options...
Dahl87banshee Posted May 14, 2012 Report Share Posted May 14, 2012 Elevation would help too.. Quote Link to comment Share on other sites More sharing options...
01yamban Posted May 14, 2012 Author Report Share Posted May 14, 2012 I'm sea leval with fmf gold series fattys , open lid air box, billet proflow air filter intake, tors removed, boost bottle Quote Link to comment Share on other sites More sharing options...
01yamban Posted May 14, 2012 Author Report Share Posted May 14, 2012 Haven't done a compression test and yes the choke tube is on Quote Link to comment Share on other sites More sharing options...
BUILDER Posted May 14, 2012 Report Share Posted May 14, 2012 With those mods 290 mains are a bit big at sea level. With your air box still on and just pipes you should be around the 270 to 280 mark. If it will not start since you put the carbs on you either have the slides in backwards or you did not get something right in one of the carbs when you cleaned them. Quote Link to comment Share on other sites More sharing options...
01yamban Posted May 14, 2012 Author Report Share Posted May 14, 2012 Well I lined the slides up for the notch to get in the groove and the ping marks show threw the little windows, I had 260 mains and 25 pilots before and it went good till hard throttle it would stumble/break up at high rpm's, so I was told by the forum to put in the 290/27.5. How can I tell if the slides are in rite? Quote Link to comment Share on other sites More sharing options...
01yamban Posted May 14, 2012 Author Report Share Posted May 14, 2012 Yes the air box is on but the lid is off Quote Link to comment Share on other sites More sharing options...
special06shee Posted May 15, 2012 Report Share Posted May 15, 2012 Well I lined the slides up for the notch to get in the groove and the ping marks show threw the little windows, I had 260 mains and 25 pilots before and it went good till hard throttle it would stumble/break up at high rpm's, so I was told by the forum to put in the 290/27.5. How can I tell if the slides are in rite? The bigger radius of the slide goes to the filter side!! Quote Link to comment Share on other sites More sharing options...
01yamban Posted May 15, 2012 Author Report Share Posted May 15, 2012 Thanks buddy I'll check it 2maro Quote Link to comment Share on other sites More sharing options...
