mpd579 Posted May 14, 2012 Report Posted May 14, 2012 Just picked up this very nice looking +4 Swing arm on a trade. The gentleman said it was a Tony Doukas racing +4. It does measure 23” from center to center so I guess that’s right. I’ve never extended an ATV before. The guy said I need a new carrier and bearings. If you can tell from the pics do I need to order the “round” style carrier?? Also I’ll need a longer chain, 130 links? And longer brake lines. Is this everything? Thanks Josh Quote
So Cal Banshee Posted May 14, 2012 Report Posted May 14, 2012 Yes you'll need a round house carrier and a caliper bracket. A 120 link chain should be good, depending on sprockets (ie...close to stock 14/41 or 15/41) Also stock length brake line will work do to caliper bracket relocating caliper position. Might also have to revalve and or change spring on rear shock depending on your weight and riding style.. Quote
