flyn_10 Posted May 14, 2012 Report Share Posted May 14, 2012 Ok guys need help ive got a 421 cub shifting problems from 3rd to 4th and so on while drag racing ive adjusted the shifter rod that goes to the shift star. It will make one great pass then damn thing wont shift if i stop and just shift it at a low rpm it works fine any help would be great thanks Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted May 14, 2012 Report Share Posted May 14, 2012 Clutch out of adjustment? Maybe its time for some transmission upgrades... best route to go if you do nothing but drag race would be an override. If you still occasionally dune ride then you want a modded stock trans. Side-cut the gears, put the shift drum on bearings, shift-pro, etc. - Jared Quote Link to comment Share on other sites More sharing options...
ticktock Posted May 14, 2012 Report Share Posted May 14, 2012 Thumbs up Jared. You can do a modded star and shift shaft. If you do those two mods together then you shouldn't do the EZ spring or the roller bearing mod on the gear selector arm. Also the drum mod bearing. Make sure you do a pancake bearing. Saving 39$ is not worth the hassle you will get. Trust me. I just found out. Adam Quote Link to comment Share on other sites More sharing options...
flyn_10 Posted May 14, 2012 Author Report Share Posted May 14, 2012 It still has the stock trans in it. The clutch is adjusted right i have no problem with that where can you get the trans stuff at i do ride the bike some too Quote Link to comment Share on other sites More sharing options...
ticktock Posted May 14, 2012 Report Share Posted May 14, 2012 It still has the stock trans in it. The clutch is adjusted right i have no problem with that where can you get the trans stuff at i do ride the bike some too Pancake Bearing: http://www.ebay.com/itm/Chariot-Clutch-Pusher-Pancake-Bearing-Yamaha-Banshee-Stock-aftermarket-clutch-/280866497251?pt=Motors_ATV_Parts_Accessories&hash=item4164f2a2e3&vxp=mtr Shift Shaft: http://www.farmandsandtoys.com/partdetail.asp?partid=247 Star Mod: http://www.ebay.com/itm/MULL-YAMAHA-BANSHEE-BILLET-SHIFT-STAR-GEAR-CLUTCH-TRANSMISSION-DRAG-SHAFT-/170830633036?pt=Motors_ATV_Parts_Accessories&hash=item27c64c984c&vxp=mtr Bearing Mod: Contact camatv, he will hook you up with a Drum to Bearing mod Adam Quote Link to comment Share on other sites More sharing options...
