This set up is spot on as i had mine dyno jetted today.
Sea level cascade 2 into 1 carb 38 air striker carb pro design
Cool head with 18 domes t5 toomy pipes v3 force reeds and reed blocks
Timing +4 fuel mixed 2 gallons. Vp 110 3 gallons premium and 18 ounces
Of klotz r50 air temp 70 dg.
Main....190
Pilot......52
Dek needle middle clip
Air fuel screw 1 1/4 out
And at these setting bike performed excellent.
So anyway for some of you wanting to know this should
Work great for you at winchesterbay or any other coastal
Riding place
What if im in Florida with that set up and its 80 degrees and your in Oregon and its 50 degrees is it still going to be spot on??????????????????????
Should be a very close set up as you would be at sea level though i think your way more
Humid so yea hmmm well i would say the only difference maybe drop 52 pilot to a 50
And on the needle maybe 2 down on clip where as im 3 down also i just got back from riding it
And im very very happy with it.Crazy enough in the whole process the only thing they changed while
Dyno jetting jt was the pilot from a 48 to a 52 and of course new b8es plugs.
But yea its great im now going to take the 2 lectron carbs off my wifes and put the same two into one
Set up as i have.
