roy581 Posted May 7, 2012 Report Share Posted May 7, 2012 This set up is spot on as i had mine dyno jetted today. Sea level cascade 2 into 1 carb 38 air striker carb pro design Cool head with 18 domes t5 toomy pipes v3 force reeds and reed blocks Timing +4 fuel mixed 2 gallons. Vp 110 3 gallons premium and 18 ounces Of klotz r50 air temp 70 dg. Main....190 Pilot......52 Dek needle middle clip Air fuel screw 1 1/4 out And at these setting bike performed excellent. So anyway for some of you wanting to know this should Work great for you at winchesterbay or any other coastal Riding place Quote Link to comment Share on other sites More sharing options...
Nightmare Posted May 7, 2012 Report Share Posted May 7, 2012 What if im in Florida with that set up and its 80 degrees and your in Oregon and its 50 degrees is it still going to be spot on?????????????????????? Quote Link to comment Share on other sites More sharing options...
roy581 Posted May 8, 2012 Author Report Share Posted May 8, 2012 What if im in Florida with that set up and its 80 degrees and your in Oregon and its 50 degrees is it still going to be spot on?????????????????????? Should be a very close set up as you would be at sea level though i think your way more Humid so yea hmmm well i would say the only difference maybe drop 52 pilot to a 50 And on the needle maybe 2 down on clip where as im 3 down also i just got back from riding it And im very very happy with it.Crazy enough in the whole process the only thing they changed while Dyno jetting jt was the pilot from a 48 to a 52 and of course new b8es plugs. But yea its great im now going to take the 2 lectron carbs off my wifes and put the same two into one Set up as i have. Quote Link to comment Share on other sites More sharing options...
Nightmare Posted May 8, 2012 Report Share Posted May 8, 2012 i would think it would be further off than that. Quote Link to comment Share on other sites More sharing options...
