Pictures are worth a thousand words huh?
The bosses that the clutch bolts screw into just sheared off, how the hell does this even happen? Lucky I a whole spare clutch from my last fiasco.... This quad is breaking my heart :(
Holy smokes, I never seen a clutch do that before. Atleast its an easy fix if nothing else is damaged.
Whats a good rule o thumb to tighten those thigs? I usually tighten em till they stop then back em out a few turns.
there is your problem. get a damn clymers manual and follow the directions EXACTLY.
I just snug them up though.
Yeah that's bad and get a close up of that basket, it looks really grooved up.
you most likely over tighten the screws and put to much stress on the inner hub.
I had this samething happen to me...as stated before it came from you over tighten the bolts. just snug them up & you will be ok.
