banshee15 Posted April 22, 2012 Report Posted April 22, 2012 if there is no washer under the main jet will this cause ur bike not to idle also on my right carb i have a leak gas is comeing out the drain plug on the bowl. i check all the screws an they are all tight Quote
Larry's Shee Posted April 22, 2012 Report Posted April 22, 2012 Don't know about idle but will mess with everything else. If float needle is good and laevel is set, try this http://www.blasterforum.com/do-yourself-20/easy-almost-free-way-stop-leaky-carbs-33335/ Also check O-ring on outside of needle seat. Quote
