I haven't tightend it yet. I was sitting on it and I had a buddy wiggle it. about 2 inches of play. I'm thinking of taking out a link. stock swinger/104 chain
if you need to take a link out at 104 on a stock swinger, its time to get a new chain. Recommend changing the sprockets too, running that loose eats them up! Call Wildcard, They stock good o-Ring chain fairly cheap and it has a high tensile strength.
Adam
Adam
Everything on the rear is new. front/rear sprocket, chain, swing arm bearing, axle bearings, axle, front/rear chain slider, rollers, brake disc. Also maybe i should have mentioned this, gearing is 14/40
104 length is stock chain length but your rear gear is smaller than stock. Lose a link if you're tensioners are maxed out
stock is 14/41. I didnt think 14/40 made that much difference, but maybe it does?
stock is 14/41
do a center to center measure and then use a chain calculator. If its all new with the smaller sprocket you could get away with cutting a link out, but you might need a half link.
Adam
the long bolts are almost all the way in. which i guess is maxed out.
stock is 14/41
Adam
Center to Center? Center of front/rear sprocket? Where would I find a chain calculator?
I wouldn't think 1 tooth on the back would be too noticeable in your chain tensioning. Did you compare your new chain to your old one?
No, I didn't. But it had 13/41 gearing on it. And actually the chain tensioners are the same as b4.
you're doing something wrong if the bolts are all the way in with a 104 chain/stock gears and still have 2" of slack. Standard slack is 0.6 inches from the middle of the chain on the top side.
loosen all 4 carrier bolt nuts, and tighten the chain by turning the lower two bolts clockwise.
Are you sure you have routed the chain correctly?
Like this:
O
O
O
nice diagram^^^^ :rolleyes: not the best solution here ive seen people lenghen the lil ajustment slot.so the carrier can slide in farther in. never tried it myself though....... goodluck
Edited by shakar
im not saying SHIT unless you paypal me 15 bucks.
am i the ONLY one that caught the " my buddies sitting on it and i'm wigglin" it???!?!?!?!?! isnt that a dutch rudder??
ohman..
ohman..
bahahaha!!!! I had to urban dictionary that! And that's somewhat right
