dieselhead Posted April 3, 2012 Report Posted April 3, 2012 so I just got back from little sahara and dropped the case oil because I started having some clutch issues. What I found was mostly black stuff in the oil which just changed from gear saver 85 to orielys 10w30 the clutch is much grabbier when first started I removed side cover to inspect clutches nothing out of the ord but could the oil switch be causing clutch fail Quote
TIM LUTZ Posted April 3, 2012 Report Posted April 3, 2012 I'd stick with the gear saver. Good stuff. Flush the O'Reilly crap out with some cheap ATF, drain and go back to gear saver. OR if you want the best feeling clutch ever and a couple more HP go with Amsoil Super shift racing ATF. A lot of pro 2 stroke moto cross teams ran this stuff before everythig went 4 stroke. Quote
