Snortin.norton Posted March 31, 2012 Report Share Posted March 31, 2012 I just put a twist throttle on my 04 banshee. The kit eliminates the top/switch assembly and also the idle adjustment. It ran yesterday but now when I kick it over there's no signs of life unless I open the throttle but even then no go. Is there another part they didn't tell me I needed or what is the problem ? Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted March 31, 2012 Author Report Share Posted March 31, 2012 Top/switch assembly is for the T.O.R.S. (throttle over-ride system) Quote Link to comment Share on other sites More sharing options...
toytech Posted March 31, 2012 Report Share Posted March 31, 2012 did you unhok the tors box under the left front of the gas tank Quote Link to comment Share on other sites More sharing options...
Overboost Posted March 31, 2012 Report Share Posted March 31, 2012 replace the boost bottle with a bigger one. it now needs more airflow supplied by the boost bottle to keep up with the new added power Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted March 31, 2012 Author Report Share Posted March 31, 2012 I un hooked the tors box under the front fender and it started up with a little help from the throttle but when I let off the throttle it quits. Why would it have added power just by switching the throttle mechanism ? Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted March 31, 2012 Author Report Share Posted March 31, 2012 Pretty sure your right just curious Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted March 31, 2012 Report Share Posted March 31, 2012 Did you add the idle stop screws? Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted March 31, 2012 Author Report Share Posted March 31, 2012 No I didn't what are they ? Quote Link to comment Share on other sites More sharing options...
toytech Posted March 31, 2012 Report Share Posted March 31, 2012 No I didn't what are they ? go to the technical info section and look here, T.O.R.S Removal. Idle Screws Install. shows you how to install the idle screw kit you need Quote Link to comment Share on other sites More sharing options...
Snortin.norton Posted March 31, 2012 Author Report Share Posted March 31, 2012 Ahhhh that would be my problem. Thanks for all the advice guys Quote Link to comment Share on other sites More sharing options...
