BooneDaddy87 Posted March 25, 2012 Report Posted March 25, 2012 Banshee will crank no problem run strong just won't idle at all. No TORS and has stock carbs Not sure of jetting has been ported. Dies as soon as I let off throttle. Thanks for the help Quote
Surfrjag Posted March 25, 2012 Report Posted March 25, 2012 clean carbs and find out what jets you have. adjusting idle does nothing? edit: do you even have idle screws? if not you can try tightning the cable on the handlebars to try and pull on the cable but i would recomend getting the idle screws installed on the carb. Quote
06bluebanshee Posted March 25, 2012 Report Posted March 25, 2012 I had same problem. It was clogged pilot jets. Quote
BooneDaddy87 Posted March 26, 2012 Author Report Posted March 26, 2012 I had same problem. It was clogged pilot jets. Cleaned the carbs adjusted the Idle screw an messed with the throttle and now all is well thank you guys for all of your advice Quote
