Remus Posted March 22, 2012 Report Posted March 22, 2012 Hey guys, just wanted to know if the sollution to running stronger lights 55wattx2 is only the rewiring of the stator with thicker windings, or is there other mods needed as well? Also should the number of windings remain the same and only the thickness be changed? Thanks! Quote
So Cal Suspension Posted March 22, 2012 Report Posted March 22, 2012 Contact Gary. Sheerider1026. He can sell you an OEM stator already re-wound. Quote
AKheathen Posted March 25, 2012 Report Posted March 25, 2012 the factory wire gauge is more then sufficient, it takes more windings, and skill. to get true 110w+ off the pipe, you need a new flywheel, or 8 poles wound or thicker poles. just remember, when you go larger on your sataor, the stock regulator only handles about 100watts long-term, so it may fail in time, and winding stators is a real pita, and takes time/tooling know-how to do. Quote
booxzzy Posted May 16, 2012 Report Posted May 16, 2012 get the LED light or install the battery and save yourself time and money Quote
AKheathen Posted October 18, 2012 Report Posted October 18, 2012 batteries still need regular recharging, and dc conversion. only way you can do this without having to always plug in a charger, is to ride around the last 1/2hr+ with no lights, and that's iffy. good news, though, if you go to mr-16's, the bulbs have become real cheap lately Quote
