balls2walls Posted March 20, 2012 Report Posted March 20, 2012 .My 04 SHEE needed a top end due to low compression, when I took off the jugs there seems to be a fair amount of play side to side in the connecting rods and next to none up and down. I went to the shop to drop off my jugs and looked at the crank they had there, and there was hardly any play... How much is too much play? Do you measure it with a feeler gauge? Quote
Larry's Shee Posted March 21, 2012 Report Posted March 21, 2012 Page 147 Clymers Manual, con rod side clearance .0098-.0295, con rod small end free play .0142-.0386 (side to side "tip") Quote
registered user Posted March 22, 2012 Report Posted March 22, 2012 normally i dont worry about the side play unless its overly excessive. up/down play, how much arc the small end swings and if the rod twists is mostly what i look at. Quote
sleeper06 Posted March 24, 2012 Report Posted March 24, 2012 you can also press them tighter and weld them to reclearance everything Quote
