007banshee Posted March 13, 2012 Report Posted March 13, 2012 Hey guys i bought some carbs.from a member on here (stock) and keep reading the.different bowls left one should have BB on it. Both mine are identical and have 1-1 stamped on the inside(only stamping or number's i can find) is this an issue? Motor is almost finished so i haven't even used these carbs yet. Second question is what should the pilot air screw be set at 2 turns? And that's the little guy with the spring on it and the screw i will be installing with the tors delete is strictly for idle.correct? I will be running 27.5 pilots and 280 mains for my elevation with fmf garth's and summer riding 60-100*. Thanks for the help guys. Quote
Jereme6655 Posted March 13, 2012 Report Posted March 13, 2012 One of the carb bowls should have a Brass Ball on it....small one....it's on a side of the bowl. That is the left carb bowl. And yes the screw that comes along with the TORS unit IS just a idle screw. Quote
bansheesandrider Posted March 13, 2012 Report Posted March 13, 2012 One of the carb bowls should have a Brass Ball on it....small one....it's on a side of the bowl. That is the left carb bowl. And yes the screw that comes along with the TORS unit IS just a idle screw. That is the idle SPEED screw, there is also an idle mixture screw on the side of the carb!!!!!!!!!!!! Quote
007banshee Posted March 13, 2012 Author Report Posted March 13, 2012 Yeah the air mixture is near the air filter side,just makin sure thanks guys. Quote
