I need some help with a good baseline of sprokets Im going to need to get the gearing down. The motor is a 7mil on alky. The frame is a lightened stock frame and is +10 out the back. The tires are 24-11-8 sls 12 pdl haulers. I weight about 145lbs
so what would be a good starting point and along with some other size sprokets that i should buy.
........18-38 .......with 1psi air pressure
You are hill-shooting right? I'd start with 15x42 and see if the bike can pull that gearing with those paddles. I'd get a 14 and 15 front sprocket and everything from 40 to 45 rear. With those sprockets you should be able to find some combo in there that will work for you. You running meth?
- Jared
yeah ill have it on meth. I also gotta gear a 421 on race gas. pretty much the same setup except 22-11-8 sls tires. what do you think for that one?
